What double sided tape should I use on my 64-bit driver kit?
When I had to have my 64-bit driver kit replaced under warranty, I removed the sheet magnet from the back of the case just in case my replacement driver kit did not come with the sheet magnet I need for the Pro Tech Toolkit it goes with. When I received the replacement it became clear that I was never going to get the magnet back so saving it wasn't such a bad idea in hindsight.
The problem is I used WD-40 to remove it, which destroyed the adhesive to an extent. I did this to avoid damaging the case to avoid damaging the old driver bit case because I had to send it back. Because I had to save the magnet non-destructively I ended up using WD40. I can't bear the smell of it and the old tape was soaked, so I had to remove the old tape :(. The problem now is that I cannot attach the magnet to the case since I do not have anything to use in terms of replacement tape.
Does anyone at iFixit have a recommendation for tape? I'm thinking about getting this tape since I live near a Walmart that sells it. If anyone has better recommendations then this, let me know. Here's one of the cheaper "wide" tape options I found that seems like a good candidate from Home Depot. I also found another option from Home Depot but it's on the expensive side and is almost certainly not going to be picked.
Is this a worthwhile discussion?
