I need someone to talk to the students again :(
https://www.ifixit.com/Device/DualShock_...
The problem I have is they removed my information on PC connectivity, like it is worthless and only useful to a small group, despite this controller being just as good (if not better) for PC gaming despite the DirectInput shortcoming since that can be fixed with emulation.
The problem I have with this is they didn't try and revise it - they decided to delete it and erased it from existence. Thankfully it's in the page history so I was able to get a copy for revision purposes. I have a new revised version to implement later on. It looks like this is the only change that I take issue with for now.
I'm not going to touch it, but I have prepared a new version of the PC connectivity section. Can someone talk to the students who did this and clarify my stance on the matter of revisions? I don't want them to make major changes unless it is actually required and if they can revise it without deleting, I don't take removal of entire sections like the PC use information lightly because Sony doesn't say anything about it.
I have a DS4 and I use it on my PC's, so I know the accuracy of that info - I didn't put anything inherently "wrong" in there, but it probably did ramble on. Rambling doesn't warrant deletion of a whole section of useful information.
Anyway, here's the new version. They will need the raw version since it's formatted, but I can provide that by eMail. It can also be pulled from this post's history.
PC Use
This controller uses Bluetooth 4.0 so you will need a USB adapter that supports Bluetooth 4.0. Bluetooth 4.0 LE is preferred to reduce power consumption.
As a PC controller, the DS4 registers as a Standard HID Device. However, it only directly works with games that support DirectInput. For Xinput games, emulation is required. While emulation does not work 100% of the time, it works in the vast majority of cases. Modern games are also less prone to controller support problems as well and work in the controller’s native DirectInput mode.
Potential Bluetooth support issues
The user of a DS4 on a PC should be aware certain features on the controller do not work without the official Sony Bluetooth adapter because they are not part of the HID Device class. The primary areas this happens are:
• Trackpad (This feature also depends on developer support)
• Headphone jack (Likely to function under the HID Device driver but not with Xinput emulation?)
• PS Button (Steam Machine/Steam Big picture Mode only)
Recommended adapters (3rd party)
NOTE: These adapters are NOT supported by Sony.
• MIATONE Bluetooth CSR 4.0 LE
• Medialink 4.0 CSR (Recommended by DS4Windows)
Official Sony Bluetooth adapter links
While this adapter is much more expensive (~$25), everything on your controller will work without an issue and you will get official support from Sony. It is up to YOU if it is worth the extra price or not, though. It should also be noted some features are developer dependent and are not consistently supported.
Connectivity options:
Micro USB
MicroUSB is the easiest option since the controller will “just work”. However, you are limited to 15ft because of the USB standard’s cable limits. Anything past 15ft will require you to connect over Bluetooth.
Bluetooth
The option of using Bluetooth allows the user of the controller to play past 15ft. The downside to this is that your performance is largely dependent on which Bluetooth chipset you have. While most work without major problems, others just do not work right no matter what you try.
