Screwdriver in step 6 (homepod)
I bought your full kit, but I can’t open the bottom cover -step 6- (after the silicone) are you using the tr6 or the t5? I’m trying both and I can’t open it
Rep: 1
Hey Ramon, you should know that the teardown should not be followed like a repair guide, and it's very likely that your HomePod won't go back together! That said, those bottom screws should be T5 Torx screws. Be sure to firmly press the driver into the screw, at a perpendicular angle, and turn slowly. If the screw doesn't turn, but the driver does, try sizing the bit up.
2 Comments
This question was migrated from https://www.ifixit.com/Answers.
by iRobot
.the correct one is #000 screwdriver Y type is right one for teardown
by Kenneth Bowron
