Howdy, Jason!
Yep, Aiden is correct. Thanks, Aiden!
If the keyboard as a whole, or a portion of the keyboard, fails to function as it normally should in the time that you are using it, our Support team can arrange for either a replacement or a return for a full refund. We ask that you reach out to them via help.ifixit.com and provide them with the original order number so they can take a look at the specific part that was sent to you, check out the testing results from when it was first stocked, and then go from there.
They may also ask you to provide them with some information, like what troubleshooting you have performed to determine that the cause is due to a hardware failure, or if software or another component is causing a conflict, whether or not the keyboard has suffered any liquid damage or if it's been dropped at all, the condition of the cables and connectors, etc. This information helps us figure out the condition of the keyboard because we otherwise cannot account for its condition once you've installed it and used it for the past year.
There are a few caveats to warranty replacements that are worth noting -- the biggest one being replacement part availability. There are times when it's difficult for us to source parts and our inventory dwindles. In the event we run out of the part(s) you're needing replaced, our fall-back option is to wait for more to arrive. Otherwise, our only other option is to setup a return for a full refund.
I hope this helps! If you have any other questions specifically for iFixit's Support team, please shoot them an email to support@ifixit.com.
1 Comment
This question was migrated from https://www.ifixit.com/Answers.
by iRobot
