Site Navigation
Your Account
Choose Language
New iFixit battery not charging
New iFixit battery is not charging in MBP mid-2012. I reinstalled original Apple battery and it does charge.
i have removed and reinstalled the iFixit battery 2 times, tried 2 different MagSafe modules, reset SMC, shutdown, restart and sleep with same results: battery is not charging.
i kept MagSafe attached for 1 hr but the light never turned amber, only green and battery indicator says not charging,
i ran the MBP for 15 minutes in the new battery to discharge (52% down to 48%) and then connected the MagSafe but will not charge.
lastly I reinstalled the original batttery and it does charge.
I believe I have a bad battery. Other thoughts?
1 Comment
This question was migrated from https://www.ifixit.com/Answers.
by
Add a comment
1 Answer
Most Helpful Answer
@kevinst - You’ll need to contact the IFIXIT Store Contact iFixit Customer Support
Score 3
2 Comments:
thanks dan, that's in process also. I was hoping for a technical solution that I could try.
by
You proved your issue is a bad battery when you tried your original and was able to get it to work.
by
Add a comment
Add your answer
kevin Stewart will be eternally grateful.
