Dan and Taylor, I have a late 2016 MacBook Pro TouchBar 15”. So far it has not exhibited this issue. It is also covered by AppleCare until Nov 2019, so I am not interested in opening the case and monkeying with the display cable to test an idea. Since Dan has had them apart and is familiar with the lay of the land in there, here are some thoughts on possible interventions that might prevent the problem. Thoughts, comments, etc,:
1) Radius and smooth the edges of the driver board that the cable is rubbing over to mitigate or eliminate the problem?
2) Cover the surface of the cable in that area with Kapton tape or similar, or even both the driver board edge and the cable surface, to minimize friction?
3) Install a semi-rigid U-shaped non-conductive “shield”, made out of a thin but slippery material, over the edge of the driver board which would increase the radius of the bend in the cable and also reduce the friction between the cable and the underlying surface?
I am not in a position to test these ideas, but my gut tells me that if I could come up with a suitable material for #3, such a shield could easily be installed by any reasonably dexterous i-FixIt customer that possesses a modicum of intellect. Any obvious flaws to these ideas? Any thoughts about suitable material for #3?
#1 can be performed with a set of common ignition point files, with care so as to not damage the cable or attached board.
#2 can be done by anyone that has wrapped a package for shipping, or for Christmas.
#3 would require some manufacturing and/or materials science knowledge, but should not be to expensive to create and I think has the best long term chance for success if installed on systems with minimal or no pre-existing wear to the flex cable.
I am not that familiar with the flex cables, but am willing to sacrifice a couple of my rPi camera module flex cables to experiment with another idea: repairing the existing cables by bridging the broken connections with insulated 32 - 40 guage wiring, covered with conformal coating and covering the repairs with Kapton tape.
There may be a million reasons that last would not work, but has anyone tried to perform a repair on a flex cable? I would be more than happy to attempt it before shelling out $600 for an out of warranty repair by replacement of an otherwise good LCD panel.
