A new idea to protect the MBP HD cable.
Full disclosure: I am changing my 2011 cable even though it still works. I am addressing it before it fails.
Along with @mayer and the method he uses (Repair Radio Episode 3: The Next Generation of Right to Repair), I came up with as a supplemental fix to protect the new hard drive cable from damage. This isn’t a replacement for his method, but it’s another protective layer that prevents cable damage. I came up with this because I had leftover removable double sided tape from one of my ideas to come up with a secondary idea to protect the 2009-12 MBP hard drive cable with a piece that can be made into a removal tab just in case.
The tape I used is now under the Scotch Create brand (3M 109 if you want the version I have since it looks like it has more tape), but the Scotch Create tape looks to be the same. My local store just had the old branded tape (3M 109). The wax backing stays on the tape and it must remain on the tape and not removed, which limits your options somewhat. I did not see a bulk option without the dispenser, so if you want to avoid it for environmental reasons you will have to break open the dispenser, remove the blade and recycle the unwanted dispenser.
You want to cut as much as you can safely without damaging the cable, since this is meant to cover the back of the cable and does nothing else.
Is this a worthwhile discussion?
3 Comments
@kristen this may also be helpful as well
by Nick
Kudos on the creativity (and for the eco-friendly tip)! Looks like a pretty durable protective layer.
by Kristen Gismondi
@kristen I wouldn't even break it open gracefully since it'll probably be melted anyway. Unless 3M takes them back and puts them on the production line after seeing if it's usable there's no reason to do it cleanly if you're getting rid of it.
by Nick
