This one needs correction!
Optical drive replaced by SSD: maximum capacity of the SSD?
The question answer needs to be corrected to the higher marked one.
Hi @danj,
As the OP accepted the other answer (on 5/12), I have to assume that’s what worked best for them. I don’t want to change that as to not set a standard of admin removing any OP’s chosen answer. Future repairers will see that your answer is voted up the most and marked as “Most Helpful.” It will be up to them to choose the correct/best answer for their situation.
I hope this makes sense–let me know if you’d like more clarification. =]
2 Comments
By higher marked do you mean with the 4 upvotes? I don't know enough about this repair to know by the content of the answers. :)
by Amber Taus
@amber - The question had two parts to it the first can the Optical Drive bay support a SSD, the second how big can the SSD be.
Ed's answer did not answer the question. His answer didn't address the question asked. His answer is a bit confused as well. As you only have to SATA ports he claims to have two SSD's and a HDD which is in the Optical Bay.
Margaux even acknowledge my answer as being correct, it appears she didn't accept it and someone else did without reading the answers.
by Dan
