First and foremost, all of the guides you contributed are awesome tutorials. If every user on our site wrote as many guides as you, I wouldn't have a job. Some of the tips that I have for you will apply to all of your guides, so I'll dedicate this answer to those.
Even though you're thinking about the particular component that you're writing the guide for, you can't forget about everything that stood in your way before you got there. If you have to take out the battery, outer case, and LCD before you remove the lens assembly in a camera, then you have four guides there, rather than one. Make the first guide and then start the next one where the first left off. Use the prerequisite guide feature on the Details page to import the beginning steps, rather than rewriting them. This is the same method we use and it makes writing 40 or 50 step guides much less tedious.
I touched on photos briefly when I talked about device pages, but I'll go into more detail here for guides. When it comes to light, you don't just want bright light, you want even lighting. You'll get that type of light from having multiple lamps with daylight bulbs in them (5000-5500 Kelvin). Harsh direct light from an on-camera flash results in a lot of glare and bright reflections. A light colored background such as white photo paper will help too, since white surfaces will bounce more light.
Just as important as the technical execution of the photos are the content and composition. It's very easy to tell someone how to do something, but it takes more work to show them how to do it. Your photos portray the actions being described very well for the most part. There are a few occasions, however, when your guides would benefit from having a few more pictures. Pulling and prying actions, for example, are much more easily conveyed to the reader with multiple pictures, rather than a single image.
It can be difficult to show two-handed actions if you're using one hand to hold the camera. If you're not already, you should set the camera on a tripod and use a 2 or 5 second shutter delay. Not only does this give you an extra hand to use, it allows you to take pictures in lower light conditions while avoiding blurry images caused by camera shake.
In order to cover the specifics of each individual guide, I'll dedicate an answer here to each one. Keep up the good work!
3 Comments
Well, I'm not watching the Olympics, I'm not really interested personally, I have been dealing with the HP A400Y during the Olympics
by Nick
That TV looks like it will be a nice VGA monitor
by Nick
Yes it does, and it is. Works good as such....
by oldturkey03
