Posting an update replaces current text - Bug!
Just tried doing an update to a post I had and in doing so the original text was replaced Vs adding to the bottom with the UPDATE heading.
Here's the Post so you can see the history. FYI I went into the History to copy back the original text. which is the brand of memory that I need to put
5 Comments
Any news on this one???
by Dan
Hmmm. I just tried reproducing this and wasn't able to. Has this been happening every time you edit one of your posts?
by Tim Asp
Still doing it Tim. The first time I thought I messed up the second time I knew and the third time still the same. Are you doing the question or the answe update? Let's make a clean test question and try posing an update to the answer which is were I encountered the problem (one I had posted).
by Dan
I tried both the question and the answers update. I'll keep digging.
by Tim Asp
@Tim - I've moved over the test question I created to Meta so you can see the history. More than one of us encountered the issue. It appears we also have a problem in the Question Update too, as well as the Answer Update function. This is to test the update function
by Dan
