Will the 64-bit driver kit fit in the classic Pro Tech Toolkit roll?
So, I have the classic Pro Tech Toolkit and am happy with it, at least for now. I like one thing about it the new one has better, though. The part I prefer about it is the inclusion of the tech knife. The new one does not include it, although I understand it's likely easier TSA compliance. It doesn't bother me enough to skip it since the blade it uses is cheap and most knives like it are using the same blade, but it's nice to have it in the toolkit without having to buy it insovidually. I also do not travel much so I can take a note to remove it if I need to take it with me.
My main issue has always been the driver handle with the 54-bit driver kit. It is too thin and has too little torque, and easily slips. I have had 2 incidents where screws have stripped, and had to get a cheap driver set locally to deal with it the 2nd time. I also thought about buying the handle and storing it somewhere in the toolkit but I might as well get the whole driver set. The reason for this is the low bit count before it's no longer worth buying bits for the 54-bit driver and it's about the same cost to replace the whole driver set.
Another problem I have noticed is the clip on the 54-bit case cracks over time.
The calculations I did to get this are as follows:
- 54-bit: 4 bits (4 bits @2.95.bit . Total for bits is $11.80 and $5 to ship. Total cost is $16.80. Price of 54-bit was $19.95).
- 64-bit: 9 bits (9 bits @$2.95/bit. Shipping is $5. Total cost is $31.55/34.95).
Seeing as I will probably lose 4 bits to wear or lose them first, it's probably better to buy the driver kit rather then the handle. However, this opens up a problem, because it may not even fit. I did a measurement of the screwdriver area and got 4 1/2 Horizontal and 9" for Vertical for the screwdriver area. Since I have dimensions to work with, I can get an idea if the new driver set would work as a retrofit. I don't know if I can since I do not have the size for the 64-bit driver kit. However, I want to be sure so I know how well it will fit.
Is this a worthwhile discussion?
