Site Navigation
Your Account
Choose Language
Discussion Topic
Do People Receive Points For PDF's
I'm wondering if people receive rep points if/when something like a repair guide or teardown is downloaded as a PDF. If not should they? The reason for asking is that I downloaded "Sony Vaio PCG-7A2L Optical Drive Replacement" for further reference at a later time. I'm not ready to vote but I think it deserves points.
Reply to discussion Subscribe to discussion
Is this a worthwhile discussion?
Add a comment
Unfortunately users pretty much only get reputation points for upvotes, accepted answers, guide likes, and guide completions. We don't have a good way of tracking clicks on resources =( You can drop them a comment, or upvote them for now, and downvote if it wasn't helpful later. You can also upvote multiple answers if you were worried about that ;)
Was this reply helpful?
Score 1
Add a comment
I don't think enough people use them as a primary source, so it may not make sense to give someone credit for a PDF download. I'm sure most people prefer to use the app or mobile site, so PDF downloads are probably not a regular occurrence.
The problem with the PDF is they are set in stone until you generate a new copy and replace the existing copy you have. This isn't always possible as soon as a guide is revised, and the revisions can be major enough it's so different the old PDF is no longer helpful. The main problem is they are static and need to be refreshed so often they probably rarely get downloaded. They do have a use, but the uses that they do well are very limited.
Is it better then nothing if something happens (example: the guide gets retracted and the author doesn't think it's worth saving)? Yes. However, most of the guide here stick unless they are really messy and aren't worth trying to recover so that's rarely going to be the case.
Comments:
@nick how is this related to the question about rep points to the author?
by
It's more in terms of how it may not make sense since they are generally used as a backup or offline solution and that it's very unlikely a lot of people rely on them as a primary source. I've removed the irrelevant parts.
by
Add a comment
Most Helpful Answer
@sodel excuse me for having to clarify your question. Remember, I am old and need to understand what you are wondering about. So you downloaded the PDF guide for the optical drive replacement from here https://www.ifixit.com/Guide/Sony+Vaio+P.... Now you are wondering if the author of this guides receives points for that. If I am correct with this, then the answer is No. The author of the guide will have received 100 rep points once iFixit approves this guide (which sometimes takes years unless you are a student <hint> @sam @kelsea). The only points the author will receive after this is by anyone marking the guide as having been completed. If you like the guide and it helps you to finish your repair, mark it as completed to say thanks to the author.
Score 2
Comments:
Oops I misunderstood, assumed this was a pdf on an Answers post!
@sodel You can also save a guide to favorites (Options>Save to Favorites), which generally gives 10 or so points, depending on how many people created the guide!
by
(Also good catch @oldturkey03 , this is a really old guide that somehow slipped through the cracks on approval!)
by
Add a comment
Join the discussion
Rock will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 0
