Site Navigation
Your Account
Choose Language
Bose Soundlink revolve II
The charging port on the speaker is damaged- I would like to have it repaired or the port replaced
Add a comment
1 Answer
Hi!
To replace the charging port, you will have to open the speaker. iFixit has a guide for this procedure for the original Soundlink Resolve which should be fairly similar, you can read the guide here: Bose Soundlink Revolve Bottom Circuit Board Replacement.
You won't need any special tools for this repair.
To find the piece you're to replace, you'll need to search online to find a dealer that suites you. You will replace a piece that holds both the charging port and the AUX port.
Good luck,
Cheers
Add a comment
Add your answer
H Schendle will be eternally grateful.
