Can iFixit add a reverse engineering section?
So I'm trying to find a new scroll wheel for a mouse, and I need to know the dimensions for it so I know if any given wheel can actually fit. The problem is, a lot of manufacturers, including the one that made this mouse, don't publish the dimensions of their products' internal components. This isn't a huge problem for things like PCBs, since size and shape aren't as big of a consideration with those, but for mechanical parts like a scroll wheel, knowing the dimensions of the part could help a lot when trying to determine if an aftermarket part can fit in your device. Currently, iFixit doesn't have a section for dimensions of parts in a device (at least to my knowledge), and I think this would be a very useful addition. If somebody is doing a teardown, they could take measurements of each component as they do so, and then add them to a database detailing the dimensions of components in a device. Then when somebody needs to know those dimensions, either because they're trying to determine if a replacement part will fit, or if they're trying to 3D print their own, they could just find the part in the database and use those dimensions. And if somebody else measures the dimensions of the same part and gets a different measurement, they could then add theirs to the database. Maybe it could average measurements together or something? I honestly don't know exactly how this could be implemented, but I think it would be a useful addition to the site.
Reply to discussion Subscribe to discussion
Is this a worthwhile discussion?
1 Comment:
Some other things this could be useful for:
Screws- TPI, screw length, etc, for determining if a screw can be replaced with another
Gears- Tooth size, pitch, diameter, number of teeth, etc, same reason as screws
Joysticks- I reverse engineered a GameCube joystick so I could 3D print some replacements (the rubber caps on the originals came off and the sticks got really uncomfortable to use). The fit was REALLY tight, though, since my calipers couldn't fit in the space I needed to measure, meaning I had to kind of eyeball it, and I doubt those replacements are coming off without a LOT of work. A reverse engineering page could help document and prevent errors like this.
by Share
Add a comment
