I want to build my own iPhone aluminum dock
Hi. I know this is not a problem but you could probably help me. Since few days, I want to build my own iPhone aluminum dock. The one Apple sells are in plastic and expensive for what it is.
My idea is to make a "basic" aluminum dock like this one Link. I would cut an aluminum piece, then cut a hole where I'll put the iPhone dock adaptor. I'd use an old cable that'd come through a hole behind it, to under the iPhone adaptor.
I want to use a plastic adaptor like this one : iPhone 4 dock adaptor, because I don't want my iPhone to be in contact with the aluminum, and I wouldn't have to cut the iPhone hole itself, I'm not that accurate.
I also think that I wouldn't be able to cut the aluminum for the cable's 30-pin connector to fit exactly in place, I'd rather cut a larger emplacement and then fix it with caulking.
I'm trying to design it with Autocad but I've never used it before. My problem is that I don't have an iPhone 4 adaptor in hands and I'd like to know the exact dimensions of it. I mean depth, length of the whole adaptor and length of the "borders" if you know what I mean.
I welcome every idea of other designs for an iPhone dock.
Thanks
EDIT : Here is more details of what I exactly want to do.
I want to design an make the dock picture in drawing 3 and 4. As I want to use an existing Apple dock adaptor (adaptor only not an existing dock, the thing we use to put different iPhone/iPod on a base station) iPhone 4 dock adaptor to fit perfectly my iPhone, I must design a hole in the aluminum to place it and to put my cable 30-pin connector in it.
The problem is that I need the dimensions of the dock adaptor (drawing 1 and 2) to be able to make the first hole at the exact dimension to fit the adaptor borders, and make a bigger hole for the rest of the adaptor.
Is this a worthwhile discussion?
10 Comments
Ben you just want a cover for the plastic dock, or you want a dock machined out of aluminium? I can take the measurements of a dock but I am not sure if that is your intent or....
by oldturkey03
Ho sorry if I wasn't clear enough. I want to make the hole thing from an aluminum piece, and old iPhone cable, and dock adaptor to fit the iPhone properly. What I need is the measurement of the little adaptor : iPhone 4 dock adaptor
My link wasn't right
by Ben
Got one of those and will get to measure it after work. Hope that will help you out.
by oldturkey03
Thanks mate! I added drawing with the measurements I'd like to have and for you to understand better what I want. Is that ok like that ?
If you have millimeter paper and if you can draw the curve of the 4 sides, that'll be too good, because the rounding would be hard to measure.
Thanks again oldturkey
by Ben
Ben I have both of those pieces and should get the dimension to you as as soon as possible. Would be cool if you had access to a machine shop and a good mill....;-)
by oldturkey03
Show 5 more comments
