Site Navigation
Your Account
Choose Language
Discussion Topic
MacBook Pro Mid 2009 guides need slight improvement
This is not a question, more in the line of feedback. I've used several guides for my MacBook Pro Mid 2009 and they've all been great. However, this past weekend I replaced the internal hard disk and while disconnecting the battery I managed to also disconnect the tiny ribbon cable next door to it......which turned out to control sleep/wake on clamshell close/open behaviour!! The cable is so tiny and flat that it actually looks like a plastic tag much like a tiny version of what you use to lift the hard disk out of its niche in the machine. Reconnecting it was easy once I took a good look at it to correctly position it, a firm push and a nice positive click and I knew it was all good.
I just thought perhaps someone should update the various guides that talk about disconnecting the battery, to make sure people know to be very careful in that area. Any slip of the spudger could end up dislodging this ribbon cable.
While my machine had its back off I took this photo, in case anyone is interested. The battery connector is outlined in blue and the little ribbon cable is in the red circle.
Reply to discussion Subscribe to discussion
Is this a worthwhile discussion?
Score 1
5 Comments
Is it on the 13” or 15”?
by
Whoops sorry, 13"
by
If you want the original photo let me know, I still have it. The rectangle and circle aren't as obvious as I intended them to be...:-(
by
Ok great. I don’t need the photo I will just add a warning to only remove the battery connector.
by
OK cool :-)
by
Add a comment
1 Reply
Most Helpful Answer
Ok I can fix that. Thanks.
Was this reply helpful?
Score 1
Add a comment
Join the discussion
fixitskiaddict1 will be eternally grateful.
