Need some feedback on test photos
Since I deal with a lot of laptops, I really need to set up a workstation just for laptop photos. In this example I used my laptop and booted into the BIOS for test images.
This setup is composed of 2 boxes I cut up (one was used for the final build while the other was cut for support structures as the box I used needed it) and 97¢ poster board from Walmart (not permanently installed). The camera I used for these test photos is a Sony a5000 with the kit lens.
In order to support my backdrop since it has a tendency to fall without support, I use my TV (monitor) as a support.
I am looking for an LED light I can use for lighting. However I found a few at Walmart I liked at the same time, but I want to weigh out my options first before I buy anything.
To provide a frame of reference for how bad my laptop photos tend to be, I present this from the Toshiba L755 hard drive replacement guide:
I am going to provide 2 sets of images:
- Raw (Unedited)
- Edited (brightness adjustment)
Anyway, here's the image sets:
Raw
Dell laptop boot image (I am aware of the ghosting; that's caused by my UV filter used to protect the lens)
Brightness and color temperature changed manually
Full auto
Edited
The only change made here is I added some brightness manually using the curves option in paint.net
Full auto
Update (6/24/18)
I went out to get a single clamp light to see how well it would work. This is what I got:
Raw
Full auto
Brightness adjustment (on camera)
Edited
Full auto
I don't have a lot of space and my desk really doesn't allow for clamp lights, outside of that area - I've made it work there but I can really only fit one without resorting to a cheap tripod as a mount. I can probably adjust it and improve things, but I need to play with placement.
Update (6/25/18)
I have played with my light placement a little more; I think I have it.
Raw
Full auto
Edited
Full auto
Update (6/29/18)
The adjustment of the lights has changed since that photo was taken. Yes, that's a lamp with a broken socket I gutted the hardware from to use as a stand. I also replaced my Feit Electric bulbs with clear Ecosmart bulbs since the vibrations early generation bulbs with a lot of electronics causes annoys me.
Full auto
Edited
Brightness fix (Full auto)
Brightness fix (On camera brightness adjustment)
Update (7/2/18)
I have made a revision to the lighting to correct some inconsistencies. I'm still using Ecosmart bulbs as I did before.
Full auto
Edited
Full auto
Update (11/11/18)
I made yet another change to this lighting setup. In this case, it’s primarily due to desk space and the fact I had a lamp with a busted socket guard nobody trusted to use safely. I took this lamp and gutted it (procedure is covered in this guide) so I can have one in the previous clamp location I liked before in the previous rounds of photos but adjusted the location of the second unit. Photos will come later as I adjust to it.
Raw
Full auto
Manual brightness (camera adjustment)
I’m not going to bother editing these. I see no need.
Is this a worthwhile discussion?
2 Comments
It looks like you're on the right path to taking some awesome photos! Is the LED light you're looking for to brighten up the photo space? If so, I would suggest going with 6500k fluorescent bulbs inside of an aluminum reflector (the kind used for reptile heat lamps).
by Blake Klein
@blakeklein I'm used to working with 5000-5500k LED's. I have found it's easier to work with them since I don't have to compensate for the 6000-6500k blue tint. That being said I can learn if they offer a significant benefit.
I'm not disregarding your advice, but things have changed a lot. I'd rather educate you on how much things have changed.
My history with CFL bulbs:
I grew up with CFL's when they were a new thing (not the early ones; later ones that didn't take a while to warm up). The ones I remember have 2 serious drawbacks:
* The first bulbs were darker then incandescent bulbs (Later bulbs are on par with incandescent).
* Mercury. It can't be eliminated. (Later bulbs reduced it but early ones have a fair amount.) The mercury makes them hazardous waste.
The benefits:
The main benefits CFL offered are:
* Color temp options
* Power consumption
The downsides don't justify the benefits, at least for me. LED is a million times better anyway.
Current issues:
The current issue is availability. Since LED's became good (and cheap), CFL's are becoming increasingly unpopular. Some retailers still sell CFL's, but not many.
The issue for me largely breaks down to inconsistent blue removal and potentially inexperience. I had a problem with this in this SSD photo and I've edited a lot out but it's impossible to clean up 100% without a retake :(.
by Nick
