Site Navigation
Your Account
Choose Language
access to own contributed repair instrauctions?
why is https://de.ifixit.com/Document/5528/Plan... not accessible or results in error 403/404 ??
even if I try from my user account, I cant access it:
https://de.ifixit.com/Anleitung/verlauf/...
I have new repair instructions ready, but I hesitate to contribute them to iFixit, if the accessibility and open access is impossible or blocked afterwards. So for me this involves a fundamental question on my willingness to share open access repair instructions here on iFixit?
Score 2
Add a comment
1 Answer
Chosen Solution
I did a bit of research on this for you to see. From what I can tell it looks like the original was deleted in 2019 or so. Beyond that I cannot say for sure what else could be the cause.
As far as recovering that guide it may be too late. But @amber can say with more certainty if it can be recovered.
I know you wanted a better answer but that's what I found.
Score 4
8 Comments:
Thanks for the tag @nick.
This was before I started at iFixit, but I'm looking into this @jo_fix!
by
@amber @jo_fix My suspicion is years ago someone flagged it for deletion, to be honest. I know we only use that as a last resort now to the point I almost never see it outside of a few rare cases, but it seemed to be a lot more readily used for a few years. I suspect this got caught in old crossfire whereas we use it as a last resort now.
by
Thank you all a lot for your sensible replys.
Can someone reload or revive it? I can search a copy in my computer for doing so.
If there appears any problem with the content, I will be happy to receive any review comment for improvement. Only losing the entire content contradicts my motivation to continue contributions. So I would be glad to grant access to the repair instruction https://de.ifixit.com/Document/5528/Plan... , even if this would require a revision now.
by
@jo_fix Sure! I'll try to do that for you, let me find out how I can make it work and get back to you after the weekend :-)
by
@jo_fix I know for a while there was a time where the request guide deletion flag was somewhat common. Nowadays it's only used as a last resort. I personally do not use it unless all other options are used first which is extremely rare.
Not sure this helps you much but I can assure you we do not use that flag until nothing else can be used.
For transparency if someone asks me directly to delete a guide I only do it if the author is aware recovery is unlikely and to be 110% sure and the only time I will do it is for the original author. I do not feel comfortable with it under any other conditions for the reason you mentioned -- loss of trust when you do not know why. The reasoning is if you're asking you probably have good reason to ask.
by
Show 3 more comments
Add a comment
Add your answer
jo fixit will be eternally grateful.
