Using a hairdryer instead of a heat gun?
Anyone think a hairdryer might serve the purpose of a heat gun for removing the glass in a cellphone display? Or is it not gonna get hot enough?
A hairdryer certainly has the capability of loosening the adhesive in many displays. Generally, if a heat gun can get the job done, a hairdryer can, as well. Just be careful not to overheat/damage the device. I'd recommend starting with a low setting to try to loosen the adhesive. If that doesn't cut it, try upping the temperature a bit. Since hairdryers are not specifically designed for this, the temperature regulation might not be quite up to snuff with the heat gun, but if you are careful it can most certainly work.
Hope this helps!
8 Comments:
Thanks- the glass in this case is shattered, would you recommend nudging the shards with a plastic spudger or guitar pick? That's what I figured I'd do.
by rab777hp
Which phone are you trying to fix? I rarely use a heat source on the adhesive of phones, I use metal spudgers or guitar picks and then scrape the adhesive off afterwards. It may take a little longer but I don't like the worry of ruining other parts.
by pollytintop
Hey Rab, I would first try to pry the display up as a whole as much as possible. Prying individual shards is fine, but be extra careful not to accidentally push them into the device or stab yourself with them!
Im replacing the glass on iphone 6 fri n IM nervous Ive did this before anyone think I can pull this off
I use an ordinary household iron on low setting, with a teatowel. You can do a quick press for 2 seconds, check, another 2 seconds, etc...check...Works extremely well. Ps no steam!!
by pollytintop
2 Comments
Isopropyl alcohol works well to assist dissolving/softening the Apple goo-along with heat lamp. (90% works best).
Also (I'm a newbee here) and don't know where to post this. A desoldering braid works well to remove solder from contacts and protect other components from the heat. My supply came from Radio Shack many years ago. Not sure wher to get it now!
by Steven Macht
Hi @Steven Macht! Welcome to the forum! This forum (Meta) is about our overall website and answering questions that are generally not repair related. If you head over to ifixit.com/answers you'll be able to help answer more repair related questions and start your own threads, too! Feel free to post a new thread on Meta if you have any questions about how to use iFixit or Meta. You can also email us at community@ifixit.com.
Happy fixing!
by Amber Taus
