For your first question, the answer is actually very simple. It's because of the difficulty of finding service material. If I have my camera handy I may make a guide but at the same time, it has to make sense. I have a policy of 2007 and up being considered for guides only, since I consider this reasonable. I don't think it's really worth making a guide for a 2002 Dell, for example. It's going to get little to no use because after 10+ years that thing is going to be treated as eWaste.
Could I do it? Absolutely, and I have before in the past but these days I stick to 2007+ for guides, since these are almost always at least a C2D, which are far more useful today then any Pentium 4.
Back when I wrote this, I was really only taking in small jobs on occasion, and this didn't happen a lot. These days, I can get them with little trouble and if I want an old system because it's going to be eWasted, it's almost always mine even without asking. This is because of my data destruction policies. My policies are HIPAA/privacy law cases get the drive back(this is a liability protection for both parties, and to help them stay in compliance. As soon as the drive leaves the door, it's a breach.), business cases are in multiple classes(they can ask for the drive at any level, too.) and home users have the choice entirely. These policies played a major role in making it easy to get good jobs.
While I am all about keeping old machines out of the landfill, I only really do that with C2D machines these days. I don't think it really makes sense to fix Pentium 4 machines when I can get C2D equipment. I'll fix it if I have a use case that needs it or it's more ideal(i.e. XP machines) but for the most part I will only fix C2D and up, and I will still use 1st gen Core i series machines. They're definitely showing their age, but I can fix that with Linux if it comes to it. I have just had too many problems with the older Dell machines to justify continuing to repair them. I have used CRT's with these, too but once again I don't keep any CRT. I stick to Trinitron rebadges and good ones like the Compaq Business ones if it's not based on a Sony CRT.
This all more or less happened, because of all the problems I had with a Dimension XPS 5150 with Win98 FE back in the day, since Win 9x was known to be very, very unstable because of 16/32-bit code. If the 16-bit code or underlying DOS code crashed, you got a BSOD since 16-bit is considered "real mode" and a real mode crash is fatal where a 32-bit crash isn't as bad. You lose the application that crashed, but not the system. Since this happened on a regular basis, so I also had to fix this on a regular basis. I also took it apart years back too. This all happened 16 years as of the initial wring, and now at least 20. Once it gets that far, it's no longer a hobby. It's a career.
1 Comment
Thank you both for your responses!
They are both really insightful!
If anyone else has anymore to add it would be much appreciated.
Thanks again!
F
by Femi
