I need the y000 bit
I have the 54 bit kit and want to verify if the y000 bit will work with this driver. Or, is there an adapter available to make it work with the 54 bit kit driver?
Thank you.
Thank you.
Hi Ed,
Yep! Our Y000 Tri-Point bits will absolutely work in your driver handle. That driver handle accepts 4mm bits, and that Y000 bit happens to be 4mm as well, so you'd be all set using it with your current kit.
For your convenience, here is where you can find that bit on our store page: https://www.ifixit.com/Store/Tools/Tri-p...
I hope this helps!
1 Comment
This question was migrated from http://www.ifixit.com/Answers.
by iRobot
