Loosing Device info when you open the Question to edit it!
@jogihara or @jarstelfox or @evan
As an example take this question clearly the device is listed
With only going into edit mode now the device info is MIA !!
If you edit the questions body the device info does properly fill back in. So it does appear to be cached somehow.
But! If you need to change it you need to start at square zero and work back up the hierarchy to the correct device.
Before I could correct the discreet model only walking it back to the next lower level and then back up or finish to the correct level.
That’s an annoying bug. We’ll look into fixing it asap.
by Evan Noronha
@evan - Thanks!
by DanJ
@evan - It appears to be fixed!
by DanJ
